im having problems with the wipers on my xantia well partial problems really
the wipers work fine on normal and fast speed and the rear works intermittent as it should.also rear wipes 3 times when washer used.
the problem is i cant get intermittent on front wipers and also when using washer the wipers dont work i feel they should wipe 3 times as with the rear.if i flick control arm down they work once... again as expected
i have swapped control/stalks for a known good one with the same results although the old one works fine in the car i swapped with
im hoping its something simple like the relay being shot but not sure where it is located.easy test will be to change relays over once i know where they are
colin
xantia mk1 wiper relay
What year is your Xantia? If its a 96 Autodata show the relay as being to the left of fuse 21/22 etc.
However I recall the relay on my 97 TD as being further down close to the carpet somewhere on the bottom row when I removed the relevant wire in order to stop the '3 flick wipe' after washing as it annoyed me at the time
It may be possible Dickieg that the relay im looking for may not be there not had a really good look before but this car is basic its a 1.9d lx lucas pump non a/c on a L plate doesnt even have a glove box light got a plastic panel over it
i have looked for the relay near the carpet but i only have 5 relays in around the area..1 by fuses is indicators orange one is for heated rear screen one white 3 pin (no idea) and then 2 4 pin light green ones the latter are down by the carpet but i do have various sockets with nothing in could it be a case of something missing rather than not working
colin
colin
That's certainly possible if it's never worked, I had that problem with my Activa when I bought it, I couldn't operate the rear windows fron the front as the relay was in the wrong slot.admiral51 wrote:It may be possible Dickieg that the relay im looking for may not be there
As far as I can work it out, the other relays will be any for of the following; sunroof, electric windows, rear fog lamps, horn, windscreen wash.admiral51 wrote: i have looked for the relay near the carpet but i only have 5 relays in around the area..1 by fuses is indicators orange one is for heated rear screen one white 3 pin (no idea) and then 2 4 pin light green ones the latter are down by the carpet but i do have various sockets with nothing in could it be a case of something missing rather than not working colin
i have pulled all relays from fusebox area and still the wipers work front and rear along with the washer jets but no intermittent or 3 flick.as the rear has a relay on the motor is it possible/probable that the relay im looking for is on the front motor and if so how do i get to it without removing front scuttle which has recently been resealed after having a new screen put in
colin
colin
