![Smile :)](./images/smilies/icon_smile.gif)
Are you sure the top bearing is worn and its not just the usual case of the bottom bush has slid down the column above the UJ creating that illusion? If so manouevre the bush back up into place and fit a ty-rap on the active column directly below to keep it in place.Dollywobbler wrote:Maybe. When I wiggle the nearside wheel at six/nine o'clock, there's a distinct knocking noise. I loose sight of the movement after it goes into the rack.
On the other issue, has anyone replaced the bearing at the top of the steering column?
