Citroen Ax question
Citroen Ax question
Could someone here tell me roughly the value of an 1994 Ax 1.5 diesel with 12 month mot in very good condition {85,000 miles} a car that's been garaged for the last five years or so.
RED 1993 TZD Turbo EST. 182,661miles
My everyday car for last 9 years, about to be seperated {July 2008}, and then i'll be Bx'less first time in 18 years....
Have you tried Parkers on line guide? www.parkers.co.uk that will give a rough guide, also look at what similar cars are going for on www.autotrader.co.uk
Parkers only give a 1997 P plate diesel - they list this as £640 for private good condition - so use that as a basis for yours.
- x 88
If the HG is strong and theres no rust I reckon you'd see £500 for that in the trader.
1990(H) 16Valve (Rouge Furio)
- x 88
If it is indeed splendid then its well worth the money mate. Most are pretty dodgey these days, and good ones can still hit 60mpg. I could probably get to Wales on just over a fiver in one if I drove at 56mph the whole way
Needs to be rot free on the boot floor in the corners, and around the windscreen edges. Check for dents under the fuel cap, they usally cause rust due to the underseal being stretched.
Wishbone bushes and ARB bushes usually knock and make sure you pop it on full lock either side and accelarate hard to listen for any knocking from the CV joints. AX's (GT and GTi aside) have 2CV like suspension travel up front and it usually cains the joints every 50k miles.
Gets 5 extra points if its an Elation model....they're quite plush
Thanks all for info supplied, i'll keep you posted as to what will happen with it, its my father in law's car and he's thinking of selling it as he's had a Nissan Terrano. Cant understand whats he's doing really, I mean going from a car that does 60mpg to a toy that does 25mpg if that.
- MULLEY
- x 88
5 speed, 3 stud wheels
- sleepy0905
