If your citroen dispatch non turbo D becomes even less powerful and begins to emit lots of black smoke check the EGR actuator right in front of you, theres a small cover held on by one torx screw, mine was disconnected and was flapping in the breeze, now wired fully open, I have driven this vehicle for 15000 miles and its never been right until now, EGR disconnect it, block up its pipes, pure rubbish.
Stewart
Tip for citroen dispatch 1.9D
TZD 19 TD one of the few
Xantia Td estate, going soft
