Hydraulic system kitbash..
Rosieuk
Post by Rosieuk » Wed Oct 04, 2017 7:43 pm
As I understand it pulling the hydraulic system off one of these cars and fitting it to another car shouldn't be that difficult.
The globes could be fitted remotely from the dampers and if the steering rack is compatible with the fluid and pressures the power steering pump could be pulled & replaced with the c-pump. The valve case, reservoir, splitter valve and all the other bits could be fitted as space allows. Although in many cases 4 x front dampers would be needed (eg the Accent LCII uses mcpherson struts front and rear (all round independent suspension)).
The only real problems I can see are whether it's possible to make up custom interconnect piping and how the height control works.. manual or electronic/electrical?
Given that the more modern a car is the more pitiful the ride, it might not be a bad idea.. I'd be interested in people's opinions..
0x
x 47
Re: Hydraulic system kitbash..
Post by Kitch » Thu Oct 05, 2017 11:38 am
My opinion would be....why?
0x
Post by Way2go » Thu Oct 05, 2017 5:10 pm
Indeed why.......why would a specialist BXForum advise someone on scrapping our now scarce cars to provide parts to jazz up an unrelated model?
If you want to improve on standard Macpherson Struts then how about:
http://www.tritekdevelopments.com/sus_ohlins_mcp.html
Happy tinkering
0x
Rosieuk
Post by Rosieuk » Thu Oct 05, 2017 5:49 pm
Happy tinkering
I don't recall mentioning scrapping a car. I don't remember mentioning that at all. I was more thinking along the lines of refitting a vehicle with parts that have been remanufactured or taking the parts from an unsavable basket case, rebuilding the bits that need it and proceeding accordingly. I think they call it recycling.
Although since apparently the piping is stainless steel that might complicate matters a bit.
My car is in for mot at the moment and I've got a kia rio as a courtesy car, nice enough but I can feel my spine disintegrating because the ride is abysmal. 5 years different from mine (newer, same company) and a 45% higher chance of spinal injuries. A retrofit kit with BX grade hydraulic suspension would transform the thing - its true that standard suspension parts would do the same but try finding springs that have a softer, not harder rating aftermarket.. About the same chance as finding bump stocks in Aldi.
0x
x 47
Post by Kitch » Fri Oct 06, 2017 9:48 am
Yeah...........erm.......
0x
Dragon Man
x 6
Post by Dragon Man » Sun Oct 08, 2017 4:24 pm
believe me, this system is only really good for the BX. i have a BX that i am currently selling because the system does not work right. its fine if you never touch it but as soon as you mess with it you are in a world of trouble.
nothing like air ride for cars without height adjustable suspension.
0x
- JohnDragonMan
Drives: a classic Panda 4x4 called Project Fallout
classic Panda 4x4 Sisley named Talon
broken BX Diesel Estate in silver that's currently for sale.
Fix it Again Tomorrow. no special tools needed, always able to fix it! :)
JayW
x 10
Post by JayW » Wed Oct 11, 2017 10:27 am
I'd think the obvious lack of understanding of the basic principles and terminology would be the second brick wall. The first, of course, again, being why?!
If you want hydraulics, just buy hydraulics, there's plenty of Chinese kits out there easier to install and better designed if you want to do Yankee style bouncy bouncy party tricks.
0x
