Stiff steering on TZD
x 12
Post by Jaba » Thu Jul 05, 2018 8:48 am
Posting this with the intention that it might help someone one day.
The powered steering on this car had become heavier recently and the steering pulled to one side quite strongly, you could feel the difference between turning to the left and the right it was noticeably more stiff one way.
The pump is good and it pumps up very quickly with no excessive clicking. I decided that the issue therefore was a hydraulic one and was either the pinion valve or the FDV playing up.
Last week while doing a clutch change I fitted another FDV. The transformation is remarkable as the steering is now nice and light and does not pull to one side.
I will have to strip down the removed FDV and give it a good clean out sometime. Never had this before in my 25 years and 500,000 miles of BXing.
The Joy of BX with just one Citroën to my name now. Will I sing Bye Bye to my GTI or will it be Till death us do part.
My Cars: Citroen BX MK1 Break.
BMW X1
x 21
Re: Stiff steering on TZD
Post by Defender110 » Thu Jul 05, 2018 4:24 pm
^^bx>
x 42
Post by rutter123 » Thu Jul 05, 2018 8:50 pm
Aren't there some tiny filters in the flow valve? Could be as simple as that. I'm sure plaeides do a service kit for the flow valve.I've never had a problem with one apart from the odd leaky pipe seal.
x 12
Post by Jaba » Fri Jul 06, 2018 11:12 pm
Yes there are filters in there. But as they get blocked up gradually they eventually rupture and allow any garbage to pass through the FDV and potentially block up the tiny metering orifices. Its an easy fix but as I have I good one in place now I will do it at my leisure.
1985 CITROEN BX 19GT C1TBX
2002 Rover 75 CDT Connossieur SE Nav Auto R40TSL
2002 Rover 45 1.6i Spirt S TAL 91S
2003 Rover 25 1.6i XL L33CHT
x 48
Post by Tim Leech » Thu Jul 12, 2018 4:59 pm
I have a similar issue with my Athena, albeit intermittent...
1985 BX 19GT Mk1
1991 BX 19TZI Auto A/C
1994 Xantia 1.8i SX
1972 Morris Marina 1.8 SDL
1979 Rover SD1 V8-S
1980 Morris Marina 1.7HL
1998 Rover 75 2.0V6 Connoisseur Auto
2002 Rover 45 1.6i Spirit S Special
2003 Rover 25 1.6i XL 5 DR
x 12
Post by Jaba » Thu Jul 12, 2018 9:37 pm
I have some ideas Tim. We can talk about it at the CCC event if you are there on Saturday ? Also need the benefit of your advice too about my Hurricane. which I am thinking of letting go.
