I've just bought a new Valeo "spine key" ignition barrel to replace the fubared "flat key" original, where the first pin is leaning out and obstructing entry of the key.novomanbx wrote:Hello from a new member
help needed!!!
I contacted AEP and got a new steering lock and ignition switch (£51.47 including delivery) it did n't quite match the old one I've taken off! Having noted that members seemed to have cracked the problem of physically fitting the lock by creative use of hacksaw I was not too discouraged: -- This was before the conversation had turned to the question of wiring!!!
Now its bank holiday weekend I 've just got the time to fit the part, however, now I've come to do it and taken the old one apart I have found that the wiring from the switch to the two connector sockets is different. So I'm stuck!
The old wiring has
4 WHITE wires leading to one circuit socket connector and
another 4 RED wires leading to a second circuit socket connector.
The unit AEP have supplied does have two circuit socket connectors the same size as the originals to plug into the circuits served by the ignition/ steering column switch but the wiring is different;
The first of the circuit socket connectors has only two WHITE wires only to sockets 1 and 4 and no connections to sockets 2 and 3
The other circuit socket connector has four wires from the ignition switch
Socket 1 has GREEN lead with an additional fly lead with a socket. There is no extra lead like this on the current set up.
Socket 2 has GREEN lead
socket 3 has an ORANGE lead
Socket 4 has a YELLOW lead.
How do I wire the new unit in, how did you do it. Would be grateful for any help I can't trace how the switches are wired from my Haynes Manual.
To cut a long story short, the car is currently with an elderly non-Citroen mechanic... he's just phoned me up to say "wiring's different mate".
So, the above post shows the wiring differences between the old and newer type switch. Now I need some advice please how to connect up the new Valeo switch to the connectors under the dash so I can phone the guy back and tell him!! I'm hoping its easy! I really want the car back!!
Cheers,
Mark.
