ive just bought myself another bx which is my 5th. anyway its come with a few issues nothing major only one im not sure about is the steering its assisted and when you turn it its lumpy ive held my hand on both front spheres when turning it frm lock to lock and on the n/s one you can feel the lumpy bits but not the o/s would i be right in thinking top mount.
any help would be gd cheers
Paul
lumpy steering
- ken newbold
Add Flow Divider Valve (FDV) to your list of suspects or Power Steering Piston Ram.
You thought it woould be easy to diagnos?
1990 BX19 TZS Auto 06/11/1989
Re: lumpy steering
350ci muppet wrote:... I've held my hand on both front spheres ... thinking top mount...
Watch out for the Peelers
BX19TRS 118K E Reg 1992-2008
BX19TRS auto abs 96k F Reg
BX19TXD 150k K Reg
BX19TXD 150k K Reg
- DavidRutherford
- BX Digit man!
Re: lumpy steering
On any other car with McPherson struts, yes you would.350ci muppet wrote:would i be right in thinking top mount.
The BX, however, doesn't have strut-top bearings. The hydraulic suspension leg takes care of that, so if the juddering can be felt through one side more than the other, then you've probably got a stiff suspension leg.
Try the "vacuum up some LHM through the breather pipe" trick. Has been known to work wonders in the past.
well the bloke i got it from said it was stood up for about 3/4 months but i think he was talkng complete bull as there was supposedly nothing else wrong with it the lhm tank was a little low as there is a little leak on the front so filled it up will keep pumping up and down and turning every now and then its fine although not as light as i remember my old gti so ill leave it for now and just use it and see what happens.
cheers chaps
cheers chaps
cheers chaps
cheers chaps
- DLM
- Our Trim Guru
What colour is the lhm? If it's lost that electric green colour or is getting cloudy and/or brown you could be due a change and filter cleanout. Suspect the pump if the car's very slow to rise on initial start-up and the red warning light comes on for a long period during lift-up.
Last lumpy steering I tackled needed the hydraflush treatment on the hydraulic system. . Also, is the steering worse at lower temperatures than higher ones?
