Pipe cleaning
Pipe cleaning
I want to try and lubricate my front struts as they are a bit sticky going up, the method listed on the DIY section of the site mentions cleaning the pipes. Is this essential, and if so, what would the best method of doing this be? thanks.
1992 BX TXD Turbo
- Citroen Sorceror
2024. TxD 1.9D estate. 'Wheelybin' - x 12
Okay, things didn't go too well. The container of LHM i used wouldnt stay in place as the suspension moved and the pipes kept slipping out. I managed to get it to suck up a little but not from low to high because the pipes would just come out. After getting my hands filthy, swearing and putting the pipes back on I tried putting the car up and down but no difference, it still sticks going up and sometimes down.
Is there any way to attach a container other than hooking it on another pipe, and to keep the pipes in when the suspension moves?
1992 BX TXD Turbo
- MULLEY
I normally use a small plastic drinks bottle to pop the lhm in, then use some zip ties to actually locate the bottle securly against the strut, that avoids the bottle from moving too much & spilling that lhm all over the floor. Or get someone to actually hold the bottle in place whilst you make the suspension go up & down.
- DLM
- Our Trim Guru
Yup - a 2-man job without artificial aids. You got a literal reply about "cleaning" from Tom (who originated the technique you're trying) because the aim of what you're doing is to lubricate the strut internals.
The only thing that ever removes accumulated (and normally microscopic) crud from any of the major hydraulic components is the temporary use of Hydraflush instead of LHM. It'd be stretching a point considerably to call even that "pipe cleaner", and it's not needed here.
One thing I noticed in using what DLM mentioned and that is the Hydraflush running in my system instead of the LHM and this issue of sticky struts has gone straight away.
1990 BX19 TZS Auto 06/11/1989
- DLM
- Our Trim Guru
My main experience of using hydraflush was on a friend's car as an early attempt to tackle a heavy, notchy steering problem after the usual checks for belt and pump problems. It was the next and cheapest thing to try, as we didn't have a known-good or reconned FDV available - and his BX has to work for a living towing so lengthy down-time isn't desirable.
It cured that problem gradually, but didn't make his sticky struts any better in that case. I suspect we caught a filter blocking-up in the FDV just in the nick of time - but I can't put my hand on my heart and say 100% that was the cause.
Over some time, I've followed a few threads on various Citroen forums where people have used hydraflush for various reasons. One thing that seems common experience is unpredictability: it's a black-box treatment, worth trying. Like a simple lhm change, effects can seem miraculous at first but improvements don't always seem to last.
Glad to hear it's worked for you in that case, kiwi.
