LHM "Y" piece
LHM "Y" piece
Does any one have a current Citroen part number for the green Y piece that fits onto the top of the LHM resavoir on some BX's?? I am struggling to get Citroen to admit to its existance at present!! Many thanks
Bx turbo diesel 1989
Bx 1.9 Rd estate 1989
Citroen Light 15 1952
Bx 17 TZD diesel turbo 1992
Xantia 1.8 16v
Xantia 1.8 16v
- Tim Leech
- x 150
Yep Ive got one mate, just need to find it though, I will be giong to my "lock up" monday to get some other bits and will have a look for you as I am sure its in there. Im only in burton so you can come get it if I find it. Its my only spare so if you come across another please put it to oneside for me.
this part still shows up on service citroen's site as part No. 5270.14 price 4.82 inc vat trade, as it comes up with a price it should still be available
Alternatively head down to your local pet shop/garden centre and use a y piece for the goldfish tank filters.
Serious thats what I did.
1990 BX19 TZS Auto 06/11/1989
- DLM
- Our Trim Guru
Good man!
Now I'll know another thing to try if I ever encounter a split y-piece on the strut returns above the r/h rear subframe again.
It's not the same diam as the air-vent t-piece (5.5mm as opposed to 4mm) but I object to paying £12+ to Citroen for a bit of rubberised plastic.... that's what I seem to recall the t-piece cost. I used a home-plumbed alternative in metal but it was a bit fiddly to fit.
- Vanny
- My Cars: BX 16v Ph2 - Jazz
BX 16v Ph2 - XPO - x 82
1" piece of washer hose, link the pipe that goes off to the rear of he car to the nipple on the tank filler with that. Pull the other length out of the inner wing and disregard it. Its a breather so that when the tank over flows it will over flow into the wing and really confuse things!
If you really want the breather, then heat up a nail in a pair of pliers and melt a hole in the top of the pipe holder (big plastic disc) about the same size as the hard breather pipe, and shove the breather line into it. DOnt drill it as you will get contaminents into the LHM.
In an ideal world, if all of the hydraulic system is in perfect as new condition then there is no need for the pipe that goes to the rear (and links to the security valve and N/S strut over flow).
The y-piece fails as a result of heat, and will likely just do the same again!
They appear to be still available so I have ordered two at £4.19 + VAT each. They should be here on wed. As the car is in daily use and I have put the last 80k on it befor the Y went hard and brittle I decided to go down the Citroen route. Although experience sayes whats listed as available dosent always turn up!! We shall see.... I will let you know what arrives. Thanks fo the interest and help.
Xantia 1.8 16v
Xantia 1.8 16v
- mat_fenwick
- x 19
