That figures.Jaba wrote:Ok had a sniff around and this is from the Rospa driving manual.....Way2go wrote: Who are "those that know" though - do they actually? Logically, keeping it in D whilst stationary creates frictional effects and heating. Clearly the box is having to dissipate unnecessary energy amongst other things. I always go to N at lights and it's benefit can be seen on the oil temperature guage. I imagine too, correct me if I'm wrong, that it probably keeps the valves and oilways with less risk of congestion if they are usually operated?
When stationary in traffic, even for many minutes, it is not necessary to move the gear lever into neutral because the torque converter absorbs the engine’s propulsion force but does not transmit it all to the gearbox. No wear is taking place. In fact, more wear will take place if you engage neutral then engage a drive gear when it is possible to move off. Most gearboxes will automatically select first gear when the vehicle becomes stationary.
I had an auto box in my GTi once. Terrible power draining things. But very enjoyable around town - apart from the fuel consumption.
I guy I know who only has an auto licence always puts his in neutral even when at traffic lights. He's gone through more gearboxes than I can tell you about.
