Citroen BX 16V gearbox change, Help!!!
Hello i need some help with my gearbox i have taken the old one down but i have problem to put the new one in. please help me with som tips and trix
Thanks in advanse Ted.
- ken newbold
were abouts are you ,
did you remove both drive shafts, if you left the O/S one in that will be why you cant get the replacement box back in,
and you could well have also bent the inner section of that shaft
- x 88
Bent it?! Doubt that! They're a bit tougher than that! Worst you'll do is wreck the balance bearing or the diff oil seal.citronut wrote:were abouts are you ,
It's an arse of a job. If you haven't got the rad out already, get it out. Make access easier.
Get the diff up over the lip on the subframe first, use an engine crane or beam to support the weight while you position it. But generally it's just that....shit. Stick with it.
1990(H) 16Valve (Rouge Furio)
Thanks for all the help.
thanks for all the help is it possible to correct the splines if you turn the right wheel? and the push the gearbox in place? as it is now the gearbox is almost in place but i think it is the splines that is the problem.
- ken newbold
- x 88
I think he means the splines on the driveshaft, possibly?ken newbold wrote:No, you need to turn the flywheel. Turning the wheel will do no good as the diff will do it's job and the input shaft will remain where it is.
Van: Last one too me about 5 hours. It's an arsehole job. Can't remove battery tray, have to unhook hydraulics etc.
MA boxes and TU engines FTW.....2 hours!
- docchevron
Ok, I *think* he's left the O/S shaft in situ and is trying to refit the box?
It's unlikely a driveshaft will cause issue's they just pretty much self align and fall in..
It'll almost certainly be that the input shaft isn't ligning up with the friction plate.
Which will be easier to manipulate with the O/S shaft out of the way...
A picture speaks a thousand words..
I dont mind doing XU boxes, but yes, TU's are so much easier it's frightening!
At the other end of the scale.... ML5's
- x 88
I'd do an ML5, but I don't have a 5 ton trolley jack to lift it up with
- docchevron
