BX wont stop
BX wont stop
Hello. When I turn the ignition key to turn by BX off the engine keeps running. The warning battery symbol on the dash is lit up. Its a diesel TZD Turbo. I have to deliberately stall it to cut the engine. Any ideas?
- jonathan_dyane
The stop solenoid on the injector pump has failed. This is a bobbin shaped device screwed into the pump on top of the pumping head (the bit that the injector pipes come out of).
A new one is about £30 IIRC. Note, there is a stop lever on the pump to use in these situations, which you can use if you want to give your clutch less of a hard time...
- MULLEY
My understanding is that there are different types of stop solenoid for the different pumps out there. If its a Lucas pump its quite easy to change, if its a bosch its harder? or is that the roto pump? I can never remember.
- mat_fenwick
- x 19
bx wont stop
Thanks for the advice so far. Its a 1991 so does anyone know if its a bosch or a lucas. I will check the pumping head see if I can spot the solennoid. Didn't have much time to look this morning but could not spot the lever mentioned to cut the fuel. At this rate I'll need a new clutch as well!
- jonathan_dyane
Bosch/Lucas equipment was fitted according to what was available/cheaper at the time, and is not linked to year; either could be fitted. Easy to identify however, they have the manufacturer written on the pump body...
On the Bosch the emergency stop lever is fitted to the front face of the pump (the bit facing you when you're standing in front of the car) and on the lucas it's on the top of the pump to the left, sharing an axle with the fast idle lever. If they haven't been operated in some years they may be stiff and a squirt of lubrication may be in order...
The only other thing that could cause that would be a wiring short giving power to the stop solenoid regardless of the ignition being turned on, however you can easily test this with a test lamp/multimeter before buying a new solenoid. More unlikely however...
- ken newbold
