My 19TRS has got a factory keyless entry system that doesnt work.
When pressing the clicker/Pliper/remote, the red LED light goes on , but the car does not lock or unlock.
Is there somewhere or some how on the car that i can check to see if there is something wrong, maybe perhaps a fuse.
I will appreciate any input from anyone.
Keyless entry system doesnt work
Grenouille Rouge
- Vanny
- My Cars: BX 16v Ph2 - Jazz
BX 16v Ph2 - XPO - x 82
Not wishing to show you how to suck eggs, but are you pointing it at the sunroof switch from outside? It is an IR system the same as on a telly and must be pointed at the sensor from outside.
You can check the plip is transmitting IR by watching the end of the plip through a digital camera (or camera phone) while pressing the button. You should see a sequence of flashes.
