Blimey! That aint bad then..
Ok, so, to complete testing here, you'll need a meter with a calibrated tacho (the guys in your workshop should have one I'm sure) and test the rev counter in the car against the calibrated tacho and see if there is any difference.
If there isn't, then the car clearly has the worng autobox in it.
If there is, you know the rev counter is a bit wayward.
Autobox Gearing
- docchevron
- docchevron
They never are, whilst NO-ONE makes a better auto transmission than Zahnradfabrik Friedrichshafen unless you can keep it in top gear all the time, it's still limited by a fluid coupling, albeit with a very clever planetary gear set..
IMHO for most BX applications I always thought the final drive ratio was too low...
Thats why I had my own built for Phoenix, shame Citroen never quite got it right there...
Either way, if your tacho is accurate it must have the wrong box in it, I'm fairly sure it shouldn't be lower geared than a valver, thats just wrong!
