Wheely good question
I got to say this but Formula 1 cars are the fastest cars in the racing world, so relatively speaking the comparison of being slowed down by a tyres grip on a normal road driven car is so minute to not be noticeable.
Now if you started to compare with tyres in say a V8 racing series or Rally driving which practically uses road standard (be them modified) cars then you can equate to tyre performance.
While we are at I am curious as to what gas is used in a formula one tyre as well.....oops now I did it.
End of the day those 4 bits of rubber are what are holding you on the road! Treat them right and make the right choices based on what you find best for you, of course on the day the tyres let go of the grab on the road you know you made the wrong choice somewhere along the chain of events! Might not be the tyres fault but your own.
1990 BX19 TZS Auto 06/11/1989
- MULLEY
Dollywobbler, after having read this magnificent thread where no one agrees on everything, but only on some of the points & then depending upon whether you're on a track or a road ,& what the weather is doing, what have you decided
- MULLEY
Wasn't sure if you'd been tempted to change your mind.
- MULLEY
They were fitted to the front, hence why i started this debate Whichever suits people i guess, personally i subscribe to the other way round, call me old fashioned
- mat_fenwick
- x 19
- MULLEY
Would that cause oversteer & once corrected you would be understeering Probably worse than just having standard understeer, or the nasty oversteer sensation, you just wouldnt know which way to turn the steering & whether to lift off the throttle or plant it Understeer ftw.
Indeed you did start something.MULLEY wrote:They were fitted to the front, hence why i started this debate Whichever suits people i guess, personally i subscribe to the other way round, call me old fashioned
I am curious how you would handle this situation?
BX is fitted with 175/70 two get replaced with 175/65 where would you fit the two new tyres?
- MULLEY
I'd never fit different profile sized tyres period
As it is, i dont even fit different axle set tyres either, even if they are matching pairs, i'd rather have safe predictable handling.
Imagine your'e going along motorway & suddenly there's something in your lane (e.g. a concrete block, as my mate found to his cost when he was on a scooter ) & you had to swerve violently to avoid the object. You will inevitably cause the car the car to slide, i'd rather have 4 wheel's sliding predictably which would give me a fighting chance to sort out regardless of whether the car has switched from understeer to oversteer & vice versa a few times as the car will bound to be fishtailing when doing 70mph.
Imagine mismatched tyres, even axle sets, what happens??? One set of tyres will have either less or more grip, it just means you've got a level of unpredictability which gives you less of a chance to sort out, could be the difference between having an accident & not.
For the sake of a few quid, i always have 4 matching tyres, i also regularly change the fronts to the rears to ensure that at least they are wearing at a similar rate. Bad enough in the dry, but in the wet it could cost you your life & any passengers with you.
It's bad enough not having any ABS in my txd, thats why i dont take the risk. Perhaps with abs equipped cars, the difference isnt quite so pronounced, but i still wouldnt take the risk as all the cars i've owned with or without abs, asr etc...have all had 4 matching tyres. Yes there's been a few times when i've had only matching axle sets, not my choice, but i've soon changed over as soon as funds have allowed & i've taken care in the wet as the handling has been on occassion, hopeless
I know some of the responses may say "I've been driving 30+ years & never had a problem", my response would be "Yet", it only takes one incident & thats that. Oh, i also regularly check my tyre pressures, at least every 2wks & always if i'm going on a longish journey.
One of the issues i've found with trying to keep 4 matching tyres, is that the tyre manufacturers have a very annoying habit of changing tyre models every couple of years or sooner, so it can be difficult to find a couple of tyres to match the other part worn already on the car, luckily the internet has managed to solve that issue for me.
a few years ago, in my previous BX (1.9 diesel) I put winter tyres at the front, and normal at the rear. The effect was wild oversteer
Oh, when it was snowy, of course.
1993 BX GTi 16V Auto
1993 subaru legacy turbo
- MULLEY
I can imagine that could be fun in the right circumstances.
I'm currently running winter tyres on all 4, & they are all matching, again i wouldnt want to mix & match winter tyres as one axle set would have not only a different tread pattern, but possibly different compounds & construction so there would be different grip levels etc....
Differant story that!akarso wrote:a few years ago, in my previous BX (1.9 diesel) I put winter tyres at the front, and normal at the rear. The effect was wild oversteer
