LHM resistant rubber hoses(BX 4x4)
hello,
does anybody know what kind of rubber hoses can I buy that are resistant to LHM? Do they have some industrial standard code? I will probably need return hoses from regulator to LHM reservoir. They are linking a little bit and cannot be ordered anymore. Code on microfilm is 96030258(probably). Some of the hoses have T splitting so I've been thinking to take T metal profile to join rubber hoses that are around 0.5 cm in diameter.
Thanks
p.s. I am from Zagreb, Croatia, driving BX 19 4x4 (carburetor) 1989. in slow process of restoration.
Thanks
Drive with style
- Aerodynamica
I'd be very careful using fuel line where oil is involved.
Had a issue on the wartburg where it was drawing neat 2 stroke oil to the carb and the new fuel line that I had fitted promptly melted and collapsed.
Also had to remove a repair from the St Tropez from the front height corrector main return which had been repaired with fuel line which wasn't compatable with oil and had split and disintegrated.
If Citroen could have used fuel line for the return pipes then they would, the fact that they utilized a specific material then that must tell you something.
Current Fleet
1990 BX 14 TE St Tropez
1986 Wartburg 353S Tourist
1973 Ami 8 Club Centrafuge
- Vanny
- My Cars: BX 16v Ph2 - Jazz
BX 16v Ph2 - XPO - x 82
LHM hose is nothing special, it is simply oil resistant hose, most fuel hose these days are oil resistant. Silicon hose should do the trick dependant on ratings.
If your really unsure simply put a piece of pipe in a jar filled with LHM. It might take some time to degrade but hopefully you'll know before it fails on the car!
yeah. current spec'd fuel hose should be fine. stuff from teh 70s, maybe not, but the 'advances in fuel technology' requires some pretty hardy hose to stay together, which will be fine on lhm.
if you were really worried you could use ATF/Oil specific stuff for things like auto transmission coolers instead, however i expect this would be about 4 times the price of standard old carby fuel hose.
most of the stuff i pulled from my d-super which i dismanlted to rebuild the suspension in my ID19 had gone so soft that you could cut it with your thumb nail. this was 'citroen specific' stuff. also it wasn't reinforced with anything either. the fuel line I use has a fibre reinforcing layer which gives me much more piece of mind than the original muck.
