Occasionally heavy steering
Just updating on this one. It had been getting worse, so I haven't been using the BX much lately. Intermittent power steering + ice and snow = not much fun!!
I've got the car booked in for FDV replacement. It rises quickly enough, so I'm not convinced the pump is at fault. Interestingly today, first time I've used the BX for about a week, the steering was generally fine on the way in. Slowly turning the wheel with the car stationary resulted in a very slight jittery feel through the wheel, but on the move, the car was consistent in its assistance.
I'm hoping to get the car in this weekend so I'll report back once all's done.
- docchevron
- ken newbold
- jonathan_dyane
- MULLEY
I'd be interested in knowing where you can get recon pumps. Has anyone on here actually taken one apart & recon'd it themselves?
- ken newbold
I have never seen or heard of anyone that has successfully taken apart a BX pump without breaking either the casing or the pulley, let alone recon one.
I would be interested to know if it has been done.
I am sure this has been mentioned many times before, but you do require to tension the pump belt very very very tight.
You may think it is ok, but sometimes it is not possible to tighten the belt to the required point, because the slotted hole in the flat curved plate is not long enough, and the pinch bolt is at the end of the slot.
Either a new belt of the correct length is required, or extent the slot in the plate to allow for more movement.
Good luck
Good luck
This is annoyingly confusing. On here, everyone says pump. Anywhere else, FDV is the culprit - with the pinion something or other being another possibility. Yet there seems to be no way to diagnose what's actually at fault other than replace each (expensive!) component in turn.
If it was the pump, wouldn't it struggle with the suspension? She's quick to lift.
- MULLEY
Don't worn out pumps become quite warm to touch? I also thought that a worn pump also makes some noise, or can it also be silent & still buggered?
- ken newbold
Not necessarily, the PAS has priority over the suspension in the plumbing.
I've come across this problem so many times now I can't count. Only once was it the FDV, in that case the PAS didn't work at all. The pinion valve I've only had to change once, because it was leaking.
The pumps are the easiest thing to change, so that's where I'd be starting. Then the FDV, then if it's the pinion valve, get rid of the car
Can't you source a secondhand pump from anywhere?
Yes worn pumps do tend to be noisy, but I've know very noisy pumps last for years
- MULLEY
Couldnt dirty lhm also be part of the problem, i thought that you were going to hydraflush the car?
TBH, if you're worried about costs, try hydraflush 1st, thats the cheapest option.
- jonathan_dyane
The steering has very different requirements to the rest of the system. The steering is a conventional system of a design that mirrors that used in Peugeots and unlike the suspension and brakes which requires low flow but high pressure, the steering requires a much higher flow rate but lower pressure. When a pump is tired it can pressurise ok, but not keep up with the flow demands for the steering.
All of the pumps I have replaced still raised the car in an acceptable manner, they just could no longer keep up with the power steering.
