MULLEY wrote:I was until this most recent fill up running on sunflower oil with derv, in a ratio of approx 75% derv to oil. So i dont think thats the problem.
Help - very sluggish car
- MULLEY
Changed the fuel filter, no difference. Checked the brakes, thats not the problem either, i'll check the pump arm position against the throttle position tomorrow & will report back.
Something which i've noticed as an example, in 2nd gear, foot welded to the floor, car revs slowly up then at say near the top end of the rev range the car surges forward, change upto 3rd, deadly slow at accelerating again.
If i use lightish throttle & change gear at 2000rpm, the car although not as quick as normal, doesnt seem that bad & can get upto about 60, always seems that whilst under load its really poor.
Does that point towards a knackered pedal box?
- docchevron
Has the throttle pedal moved away fromt he brake pedal towards the O/S of the car??
I'd be thinking about checking the cam and pump timing just in case the belt has skipped a tooth..
At this stage I'd also think about undoing the injector pipes off the pump and turning it over to roughly guage how much fuel is actually being passed by the pump.
Could be the stop solonoid is on it's way out I guess, or, just maybe the veg oil has murdered the pump.. since it will, even a bosch pump eventually..
- MULLEY
Hmm, interesting thoughts Doc, i'm hoping that your wrong (in a nice way of course).
What would skipping a tooth on the cambelt actually feel like when it happens? Does this affect the idle from cold or hot? The car seems to tick over as normal, & the noise from the engine appears fine. I have managed to get the car upto 100 during my italian tune-up & it seemed fine.
Not sure about the throttle pedal, i think it's in the correct position, how far would it have to have moved?
If the veg oil has killed the pump, wouldnt the pump be leaking fuel & also run as rough as a badger? Neither of which its currently doing.
- MULLEY
I've had a look at the throttle pedal, it does appear to be at slanted angle from left to right with the bottom part closer to the door than the upper part. Should it be dead straight? This could be the cause of the problem
- MULLEY
Yesterday, i put approx 1 litre of petrol in the tank to see if that helped with thinning out the remaining oil to see if that helps at all. Initially it only seemed to make a minor difference on the way to work this morning, but on the drive home the car seemed a fair bit better, still not 100% but a lot better than it was.
I'll keep an eye out for things & report back on here, lets hope its not a bust pedal box afterall
- MULLEY
Not changed the air filter, its a K&N so in the summer i removed it & cleaned it, so it won't be that. I've got a suspicion that its a bust pedal box, although no one has commented on my description of the pedal position on my car?
No idea about an air leak, would that affect the idle at all & starting the car up? All of which are fine.
- ken newbold
A broken pedal box is the easiest thing to diagnose.
Get your head down in the footwell with a decent torch. Have a look and feel if need be, where the right angle bend is on the back of the pedal box, on the right hand side where the accelerator pedal is bolted through it.
If nothing is visible, try moving the pedal from right to left and keep looking and feeling for cracks or "give" in the metal.
Has anyone suggested sludge in the tank? I had similar and persistant troubles and went through the whole range of possibilities : air leak ( also a possibility), diesel heater ( only on Mk.1s?) filter etc.
It was Doc who suggested having a peek in the tank : the fuel pick up was completely sludged up and it was a miracle it pulled anything at all. As well as that I had a pleasant hour 'fishing' through the access hole lifting out virtual jellyfishes of sludge!
