andycadabra wrote:
Kiwi - the red radiator level warning light has been dodgy for ages coming on and off at will so I've never taken it that seriously. According to the workshop manual the 'temperature warning switch operating temperature' is between 103 and 107°C, and the 'emergency temperature warning switch operating temperature' is 110 - 114°C.
I would guess that the Orange light would be indicating the lower of these two ranges, and one to the right, or at the top would be the emergency one, operating at the higher range, and might be red?
I never took my low level light to seriously either, just kept topping it up when it did come on and replaced it and it still came on. Meaning a problem! But I did avoid boiling the coolant or hot air that you would be creating in the system when it got low.
Your aware that water boils at 100c but boils lower at a higher altitude! Which is probably why I never got to see the lights of death when my head gasket was on its way
Do you use an anti freeze coolant or just water?
Seriously though it is a design flaw to aloow warning lights to activate at 103c and certainly allow them to reach 114c
At least you have now acknowledged your HG and head is fubar!
