Creaky front suspension strut?
- pindimar
- My Cars: no longer any BXs but do have a Xantia
Front struts
speaking of the struts, without things getting too drastic, what are the first signs that the struts have passed their use-by-date, I wonder?
I get the feeling that the front suspension "bottoms" when I hit a pot-hole at more than very moderate speed. Well, not "bottoming" but noisy, at least.
GregF
GregF
- Aerodynamica
Re: bx struts
Was this a response to my suggestion? if so - I said 'Bushings' not 'bearings' Bushings = bushesdjm666 wrote:it could well be the bearings in the front arms? even though the bx has not had bearing in the front wishbones since the mark 1.
the later BX's have bushes.
you could be right on the anti roll bar side of things. i have never had
Graeme M
CX 2400 Pallas LPG
2CV6 dolly (SORNed)
Mk1 Xantia 1.9TD SX
'c'est hydropneumatique'
CX 2400 Pallas LPG
2CV6 dolly (SORNed)
Mk1 Xantia 1.9TD SX
if the suspension bottoms i would not think it to be a problem with the struts straight off.
if you get bad feed to the return it is usually the struts on the way out blowing off returns.
they just usually make a noise and anoy the driver more than anything.
unless you go to hot into a hump back bridge and leave the ground they bottom then. my tzd nearly died that way. ha ha, that was due to corrosion and electrolosis think that how it spelt. and the bridge being the final straw it blew lhm every were.
all right then bushings. sorry read it wrong.
David Musk
TXD Turbo 92
4X4 Estate 90
CX25GTi Turbo 85
TXD Turbo 92
4X4 Estate 90
CX25GTi Turbo 85
Are these bx struts?
http://cgi.ebay.co.uk/Shock-absorbers-C ... 2ea7df13b3
It does say shock absorbers??!!!?
- mat_fenwick
- x 19
Yup - they're spheres
Have you ever reconditioned a strut Mat? I was thinking I might get a couple of old ones and have a go, but I don't know if I can even obtain the kits... Maybe someone knows the French for "strut" - and I know it's not Napoleon, or promenade or marche! (Well no, I don't come to think of it).
- mat_fenwick
- x 19
That would probably get you by if you were in France, although my usual method is to point at the relevant part and say the English name in the most French accent possible...
I've never rebuilt a strut myself but do have a set spare 'just in case'! There is a well witten guide on how to rebuild them here.
Thanks - that's the guide that gave me the idea to have a go. I've just got to find the kits now. I'll ring 'Pleiades tomorrow (surely a lesson in itself as to how not to name a business!). Their website address is dead so I'll try the phone.
I've been quoted a price of £75 supply and fit with a second hand strut but I'd rather have a strut that I'm sure is good...
- mat_fenwick
- x 19
So are you going to get one or both? Perhaps a spare too?scarecrow wrote:I was offered a genuine Citroen strut on import for ------- over £500 plus VAT.
If you could find a dealer that still has one in stock, they may be keen to get rid of it at a more realistic price - you could point out that they are unlikely to sell it for the full price now. That approach has worked well for me in the past; I find out from my local dealer if any other dealers have an obscure part in stock, then phone up the said dealer and make an offer.
That reminds me, my Citroen dealer said they had some BX bits in stock they they were going to bin, and I'm still waiting for a call back to arrange a time to look round 'upstairs'.
Slightly worrying the service kits are apparently NLA, but I wonder if you'd get a different answer if you supplied the part numbers...
No, the guy had the part No.s for the kits - 95 597221 (£4.33) and 95 650941 (£29.33).
I'd like to get the specifications for the various components of these kits to try to source them individually - the parts bloke suggested the seals might be available from gearbox overhaulers. If they can be made up from other sources there must be a market for them, or at least for struts reconditioned using them.
I'm also wondering if xantia struts could be modified to fit the BX - I have a club-hammer!
