loss of water in the radiator!
Hello
I have a 8v petrol bx-89-225K,and every week i add about a half litter of water(green prestone),and another prob is the steering heavy when the car is cold -maybe the pump shoud be changed .
some suggestions for solving this prob ,thanks
Regarding the heavy steering, this current thread might be worth reading;
http://www.bxclub.co.uk/forum/viewtopic.php?t=11584
I'm sure someone more mechanically minded will be along soon and ask the necessary questions to narrow down the possible causes of the coolant loss.
19 TGD estate
17 TZD Turbo hatch
17 TZD Turbo hatch
- ken newbold
the rad should be filled to the top but only to the bottom of the filler neck,
dose this car start evenly on all 4 cylenders from cold,
remove the spark plugs and check the colour of the electrodes/tips, they should all be a biscuity colour,
for the steering firstly check the hydraulic pump belt is very tight, then check the hydraulic tank filtters are clean,
you should also check the LHM level by raiseing the car to its highest setting on level ground, check the yellow disc in the sight glass is between the two red bands (this is the top disc in the sight glass/level indicator)
if these are all ok it could be the pump on its last legs,
what mileage has the car done
A confusing statement, as the filler goes down almost to the bottom of the radiator? Surely the correct fill level should be a few inches below the filler cap to allow for expansion.citronut wrote:the rad should be filled to the top but only to the bottom of the filler neck
Some of the books refer to a radiator dipstick tube, but I have never seen one of these even on new BX's I had.
You saidRgod wrote:have any suggestions why the water may disappears ?and how much to fill it ?
Half Litre ever week is that after driving or from just sitting there without running the engine?every week i add about a half litter of water(green prestone)
Way2go as sort of answered this already for you.
It is expansion! The Radiator will never be full right to the Radiaotor cap but will drop down a couple of inches due to expansion.
When you check the water at cold if it is level with the top of the Radiator ie down a few inches in the filler neck tha is ok. You also have a back up with a Low level Coolant light on the dashboard connected to a probe at the lower part of the radiator filler neck. Check that it works! Easy way is to remove it then turn key to accessory postion then you will see the yellow low coolant light on the dash.
Sounds to me that you are overfilling the coolant and not allowing for expansion.
the part i would call the neck is from the top down to the top of the rad eliment/core, were there is a ledge, this ledge is about were the level should be,
also i have had BX's with a dip stick/tube,
after driving every day,in the end of the weak a fill up a half littre.
I have never seen the orange lamp get on,i have a red one in the middle and it works before i start the car and then its off,the water can get down and the lamp doesnt works.
I think i have a leak of water to the head,because in the filler cap oil there is a little white ,mixture of oil.
What you dont say is how far your travel in theat week and the type of driving ie short trips.Rgod wrote:after driving every day,in the end of the weak a fill up a half littre.
Regarding the white mayo you see in your Oil! Might point out it is winter in the north and the BX is well known for developing mayo in the filler cap due to condensation from the coller conditions and short journeys.
If you are filling the Rad to the top of the tube YOU WILL lose approximately 1/2 litre due to expansion. Within probably the first journey where the engine has reached temp and kicked in the fan.
Sounds like you panicing without real proof of Head Failure.
Well that answers it thenRgod wrote:I drive short distances,about 25 KM a day 40-50 MPH .
Short distance low speed = Mayo build
As for that water loss that also sounds normal given the Filler down the side of the radiator is the expansion tank. I assume you are using an anti freeze/coolant mix as well? Antii freeze/ Coolant acts as a coolant hence the name and prevents the water in the Radiator expanding to much hence the water loss.
When was the last time you changed the Oil? If your driving short distance I would recommend the 6 month or 5000km regime given the build ups you are causing.
Does sound like you just need a good service though given your passed history with this car.
