I'm getting a chirping sound which I think is coming from the belt driving the HP pump. Just had some work done on the engine and I don't think they tightened it up enough as there is about half an inch of give in it. The sound is intermittent and rev dependent, and lasts from 1 to 3 seconds.
Is the solution to tighten the belt, or to squirt silicone spray at it, as I've read elsewhere on the forum, might solve the problem?
Birdsong under the bonnet..
- mat_fenwick
- x 19
Sounds like the HP belt, the (slightly tongue in cheek!) solution is to tighten it up as much as you think possible, then give it a tweak...
Seriously, they do need to be tight - I use a lever between the gearbox and the pump body to tension it and then tighten the nut locking it in position.
EDIT - you beat me to it Brian!
