Front struts.
- Stinkwheel
Front struts.
Are they rebuildable? can you still get new ones?
Basically i feel the ones on the St Tropez are acceptable right now but do have an annoying amount of 'stick-tion'
in my old days of BX'ing i used to just go to the local scrap yards and buy the struts that appeared new or newest, this worked fine then but we all know that BX's have dissapeared from scrappies.
Any suggestions please?
Doctor Of Gonzo Journalism!!!
93 BX TZD Estate
90 BX 14TE St Tropez
93 BX 19 TXD Estate
92 BX 16TXi
77 Ami 8 Break
79 Acadiane
81 Dyane6
84 2CV6
85 GSA saloon rally car
93 BX TZD Estate
93 BX 19 TXD Estate
92 BX 16TXi
77 Ami 8 Break
79 Acadiane
81 Dyane6
84 2CV6
here are the two kits for overhaul parts required
95597221 CYLINDER KIT 4.48 GBP 5.26 GBP 5.26 GBP
95650941 CYLINDER KIT 25.83 GBP 30.35 GBP 30.35 GBP
looks like both kits might be required for one strut, if they are still avalible
- MULLEY
In the meantime, can't you either zip tie them onto the pipe where it keeps blowing off or using one of those metal clip thingies (sorry brain has gone to mush & can't remember what they are called, doh). Thats what i did & seemed to work, gave me enough time to sort out a 2nd hand strut & not having to worry about them blowing off whilst i was stll using the car.
- MULLEY
Oh dear, hope you start feeling better soon. Yeah, car maintenance alway's takes a back seat when i get poorly, so know where your'e coming from....
Risky, you might blow the Octopus apart as they're designed to cope with leak-off not heavy flow!MULLEY wrote:In the meantime, can't you either zip tie them onto the pipe where it keeps blowing off or using one of those metal clip thingies (sorry brain has gone to mush & can't remember what they are called, doh). Thats what i did & seemed to work, gave me enough time to sort out a 2nd hand strut & not having to worry about them blowing off whilst i was stll using the car.
- Stinkwheel
120 plus vat seems reasonable for re-con ones TBH to my mind anyway. Considering what price new ones were going back a few years.
Personally im gonna try and find a couple of reasonable used ones and then re-build them myself. (assuming i can get the kits mentioned)
Its not a problem driving it at all, they are nowhere near as bad as the ones on my old silver 16v. they were bad.
93 BX TZD Estate
93 BX 19 TXD Estate
92 BX 16TXi
77 Ami 8 Break
79 Acadiane
81 Dyane6
84 2CV6
93 BX TZD Estate
93 BX 19 TXD Estate
92 BX 16TXi
77 Ami 8 Break
79 Acadiane
81 Dyane6
84 2CV6
- MULLEY
Didn't realise that could happen way2go
- mat_fenwick
- x 19
Ha! Thanks Mat. Was a statement of fact. I'm quite happy hurling money at the BX as it's a great motor. Found some rot under the washer bottle yesterday though, reminding me that bodywork is likely to be the next big expense...
EDIT - Actually, how big a job is strut replacement? Could I reasonably expect to do it myself with my feeble toolkit?
- Stinkwheel
yes Ian,
you could manage it no bother mate.
Mine is rusty under the washer bottle too, when ive finished fettling the Acadiane for its MOT then i may pull the front wings off the St Tropez and do the welding it needs and the inner wings bits again but properly
93 BX TZD Estate
93 BX 19 TXD Estate
92 BX 16TXi
77 Ami 8 Break
79 Acadiane
81 Dyane6
84 2CV6
93 BX TZD Estate
93 BX 19 TXD Estate
92 BX 16TXi
77 Ami 8 Break
79 Acadiane
81 Dyane6
84 2CV6
