16v Exhaust?
The rear box, cross box and intermediate pipe for 16v, GTi, TD connect with flandge's, all other modles the joints are internal type conections, were one bit goes inside the other,
BOSAL's online cataloug is also a good reference
http://www.catalogue.bosal.com/pages/ex ... search.php
I wasn't able to remove the exhaust last night for inspection as we're having a cold spell here - winter has returned with a vengeance, it was -7 last night.
Anyway, I noticed that there are very slight amounts of exhaust coming out of the heater vents inside the car! As I mentioned before the middle pipe has a hole in it but the intake for the heater is somewhere near the manifold . Anyone had this before?
are you sure you has exhaust fumes comming through the heater vents,
may be its steam from a leaky heater matrix, as the cabbin air intake is in the scuttle between the engine bay and the wind screen,
- mat_fenwick
- x 19
Perhaps Todd could sit in the car with the engine running and windows closed as a test?
If he reports back that his pores are cleansed and he feels more relaxed after his impromptu sauna then we'll know it was steam. If he doesn't post back it must have been exhaust fumes after all...
In all seriousness, I know my shell had a rubber grommet above the exhaust in the floorpan below where the heater matrix is. This is to drain any condensed water from the evaporator on A/C cars. Could it be possible that exhaust fumes are coming up through a failed grommet and seeming to come from the footwell vents? How does the exhaust sound?
Yeah, thanks Mat! Very advanced rubber grommet concept too ( though I've learnt on the BX every theory has to be considered)
Malcolm, I too had considered it to be steam but the engine wasn't really warm enough at that point to generate steam.
It just comes in occasional puffs through the top dash right hand vent - it's a cloud of something but I don't know what as I haven't been able to 'sniff' it as such as I'm sitting on the other side.
The exhaust sounds alright considering there's a hole in it. But fumes exit from this broken middle pipe and roll along the bottom of the car. This obviously wouldn't happen if it was moving but the car is more or less stationary as I'm working on it for its TÜV ( MoT).
I couldn't think how exhaust fumes could somehow penetrate the heater matrix. Something tells me that the TÜV is going to be quite an undertaking!
Vanny, I know it's an odd one! I have assumed it's exhaust as there's a petrol smell in the car sometimes. It appears as a small low density cloud for a very short duration.
Simon, I don't have A/C yet - this is the next project as I have a donor GTI with 'air' though it's sat for ages so the system might have corroded or have other problems. Anyway, the condensation idea is also interesting considering how cold it's been here recently - there was even snow on the valver the other day though it's sat inside a barn. The roof tiles must have lifted slightly with the winds.
I'm waiting for the weather to break to get back to work. Then they'll be a load more questions for the 'BX detectives'!
It took me longer than expected but I got under the car yesterday and cut the exhaust off with an angle-grinder ( horrible).
The intermediate pipe had been welded (!) to the front pipe and the expansion box. I think this is why the bloody thing fractured as it had no flexibility. When I removed it, I found that the end of the front pipe was rusty mush and that the expansion box was full of water and has therefore probably rusted out from the inside.
So, I've either got to get a new front pipe if I can find one or weld on a new section, if I can find the right section pipe. I've no idea where the water in the expansion box came from - it did sit for five years before I bought it but...?
This car was last owned by Wyatt Earp/ Billy the Kid or similar resident of the Wild West!
( If anyone's got a spare 16v front pipe lying around.. I know a good European courier service)
- rayfenwick
FFS... I'm giggling like a loon now!mat_fenwick wrote:If he reports back that his pores are cleansed and he feels more relaxed after his impromptu sauna then we'll know it was steam. If he doesn't post back it must have been exhaust fumes after all...
Ray
www.citroencarclub.co.uk
I found a front pipe here in The Fatherland today for €107 reduced from €180 - made by Walker - one piece only. Probably better than welding and farting around bodging and it can hold the rest of the heap together!
That's worn me out writing that better have a
