I Have a Cit BX 19 TGD and I have a leak on LHM fluid from a metal pipe, but I am unsure of what the part isd called or if anyone can suggest if it can be brazed? the front pressure regulator has two metal pipes coming from it, they coil round in a spring like fashion and the leaking one seems to head towards the drivers side and goes into the steering rack. any help would be appreciated. I am not very technically minded. Can these be repaired or do I have to get a new part?
thank you
Mark
