YET another HP pump question.
- Stinkwheel
Hiya guys an gals,
right, silly question time.................my 14TE, what pumps are fitted to these? Same as diesel or petrol or unique?
Or what models pump should i look out for if i want an emergency spare as it were?
Im not worried about its output at all, its quick as i could want to pump up and not having power steering its not working hard BUT if you watch it whilst running the pulley looks to be running well out of true and im now paranoid about failed bearings etc etc.
Doctor Of Gonzo Journalism!!!
93 BX TZD Estate
90 BX 14TE St Tropez
93 BX 19 TXD Estate
92 BX 16TXi
77 Ami 8 Break
79 Acadiane
81 Dyane6
84 2CV6
85 GSA saloon rally car
93 BX TZD Estate
93 BX 19 TXD Estate
92 BX 16TXi
77 Ami 8 Break
79 Acadiane
81 Dyane6
84 2CV6
- MULLEY
Diesels & petrols are different, i think that there are only 2 pumps, so one type will only fit that type of powerplant. I stand corrected if the more learned can share any differences & more pumps than what i think there are.
- docchevron
It's been a long time since I've looked at a 14TU car. Any chance of a piccy?
The 16 valve has a different pump, but suspect the 14 has a standard non 16v petrol pump..
- mnde
- Meteor Man
Nah... I can't find the thread but didn't Owen S have a thread about this when he wanted to replace the pump on his BX14?
AFAIK the pump on BX14s is entirely different to the 16/19 non 16v pump.
EDIT: Here it is http://www.bxclub.co.uk/forum/viewtopic.php?t=5151
Although Jon W says he thought on late BX14 models the pump is the same as 16/19... We need a picture!
Mark.
Mark.
- Stinkwheel
Here we go then, better late than never................
Is that any use to show angles etc?
93 BX TZD Estate
93 BX 19 TXD Estate
92 BX 16TXi
77 Ami 8 Break
79 Acadiane
81 Dyane6
84 2CV6
93 BX TZD Estate
93 BX 19 TXD Estate
92 BX 16TXi
77 Ami 8 Break
79 Acadiane
81 Dyane6
84 2CV6
- Stinkwheel
- Stinkwheel
Wellllllll.
looking at that lovely new 16 petrol pump, i think (fingers crossed) a 16 petrol one would fit OK with a little fiddling.
Anyone got a 16 petrol pump i can try?
93 BX TZD Estate
93 BX 19 TXD Estate
92 BX 16TXi
77 Ami 8 Break
79 Acadiane
81 Dyane6
84 2CV6
93 BX TZD Estate
93 BX 19 TXD Estate
92 BX 16TXi
77 Ami 8 Break
79 Acadiane
81 Dyane6
84 2CV6
- Stinkwheel
OK no answer on has anyone got a 16 pump.
Next anyone actually know if this 14 pump is the same as any others now we have a pic?
Ta
Ta
93 BX TZD Estate
93 BX 19 TXD Estate
92 BX 16TXi
77 Ami 8 Break
79 Acadiane
81 Dyane6
84 2CV6
93 BX TZD Estate
93 BX 19 TXD Estate
92 BX 16TXi
77 Ami 8 Break
79 Acadiane
81 Dyane6
84 2CV6
- mat_fenwick
- x 19
This would suggest that the 1.4 is different to the rest of the petrol range.
- Stinkwheel
Thanks all, im very worried about the run out on the pulley and i cant afford to be without the car for now.
So tim, if your friend has a spare id be very interested if its surplus to his needs.
93 BX TZD Estate
93 BX 19 TXD Estate
92 BX 16TXi
77 Ami 8 Break
79 Acadiane
81 Dyane6
84 2CV6
93 BX TZD Estate
93 BX 19 TXD Estate
92 BX 16TXi
77 Ami 8 Break
79 Acadiane
81 Dyane6
84 2CV6
