Does anyone know the part number for the pipe that goes from the pump to the accumulator, it has 12mm ends.
Is it the same as a turbo diesel, I have been told it may be.
Thanks
Part number for 16v hydraulic pipe
- docchevron
Haven't got the part number to hand, but I can tell you it isn't the same as a diesel, or indeed any other flavour of BX..
I might have one knocking about if you need one?
I think I do, PM on its way.
There was a slow drip from the end, I replaced the rubber seal and now it is a green fountain. So bad I thought I had somehow left the rubber seal out. Took it apart again, tightened it up very carefully to make sure everthing was in the right place - still green fountain.
Douglas ifyou still require it i belive this is he corect pipe
96034027 HYDRAULIC TUBE 12.47 GBP 14.65 GBP 14.65 GBP
i know the last one i fitted to a valver the owner bought a copper knickle one, made up by Martin at PLEADIES,
turned out it fractured because some of its mountting brackets were missing
