diesel fuel pipes
Dennis Rosser
diesel fuel pipes
Post by Dennis Rosser »
Hi, is it possible to buy new diesel fuel pipes for my bx estate ? Mine are rusting away. Thanks.
cauchoiskev
Post by cauchoiskev »
Yes, still available from dealers
parts n° 95594177 and 95594178
about 20 quid the pair, well worth doing !
Post by Mothman »
Hi,
did mine on a L reg Estate 4 years ago, still going like a good un but they split and were leaking badly. Not a too difficult job i seem to remember.
kermit the frog
Post by kermit the frog »
I would tend to go for copper pipe as a replacement and the correct diameter pipe can be obtained from a commercial vehicle brake supplier.
Also you will find it much easier to fit as it is easy to shape.
It will also outlast the OE pipe.
You should require about 3 mtr's/10ft this will be more than enough.
Regards Kermit
kermit the frog
If replacing 2 pipes you will need more than 3 meters
Sorry
Regards Kermit
