Hallo everyone
Does anyone know what the Citroen part number for the seal for the larger hydraulic pipe is?
I need this info urgently.
The smaller pipe seal part number is 96085785
So that is NOT the one I'm after.
The seals I'm after are for the larger High Pressure pipes that go into the Flow Diverter Valve.
Thanks in advance and best regards
Larger Hydraulic Pipe Seal part number * URGENT REQUEST *
19 TRS Estate
In the past: 2CV, Dyane 4, GSA
Be faithful to your BX and she'll be faithful back
here is the part No. for all three diferent size's of pipe seal found on BX's
96 085 785
FLEXIBLE LINING
TUBE 3,5
96 085 784
PIPE LINING
TUBE 4,5
96 085 783
TUBE 6,35
the one your after is the last one,
from the dealer they are 3.33!!!!!!!! trade each inc VAT
i would not buy them from citroen but from Martin at
PLEIADES 01487 831239
FLEXIBLE LINING
TUBE 3,5
96 085 784
PIPE LINING
TUBE 4,5
96 085 783
TUBE 6,35
Absolute Gem!
Hallo Malcolm!
You are an absolute Gem! AND a huge credit to the BX club!
Thank you very much!
Best regards
Best regards
19 TRS Estate
On the 4.5
Hallo again Malcolm,
On the 4.5 mm ones where do they fit unto and how many of the seals, approximately, does one need for the whole car? (Worst case scenario, in the event that I have to replace everything).
Best regards,
Best regards,
19 TRS Estate
in all the years i have worked on and around citroens i have very seldom fit new seals, all i do if they arnt mangled is pick off any strands of rubber sticking out, then re/use them,
the 4.5mm seals are for the pipes with 9mm (spanner size ) pipe nut, cant think off hand
4.5 mm seals
Hallo Malcolm,
That's a good tip, (9 mm spanner), so I'll keep a look out.
By the way I have ordered some seals from Martin, (PLEIADES), and he is sending them by post today.
I also got a pk of 10 4.5mm seals .. hope that will be enough.
I'll post something on this thread when they arrive.
Thanks again Malcom -- A million times over!
Best regards,
Best regards,
19 TRS Estate
- mat_fenwick
- x 19
on a standerd BX non ABS there is one pipe conected to the regulator which has a 9mm pipe nut, this one will be 4.5mm, it terminates at the safty valve,
here is a list from service citroen's site
95 596 578
HYDRAULIC TUBE
DIAM 4,5-1750
- UNTIL RPO No. 04101
96 033 162
DIAM 4,5 -2200
- SINCE RPO No. 04102
DIAM 4,5 -2200
FOR PUMP 6 + 2
95 597 151
NFP
DIAM 4,5-1885
- BVA UNTIL RPO No. 04101
96 033 161
NFP
DIAM 4,5-2200
- BVA SINCE RPO No. 04102
95 596 578
HYDRAULIC TUBE
DIAM 4,5-1750
96 033 162
DIAM 4,5 -2200
DIAM 4,5 -2200
FOR PUMP 6 + 2
95 597 151
NFP
DIAM 4,5-1885
96 033 161
NFP
DIAM 4,5-2200
