Are there any means of giving my TD a bit more go? I dont mean dropping in a V8 truck engine or anything daft,just thought there might be some after market higher output turbos or something from the pug boy racers out there?
Richard.
17TD. More power?
17TD. More power?
1985 MK1 BX Digit
1986 MK1 BX Leader
1988 19RD
1983 Tin Snail
1986 MK1 BX Leader
1988 19RD
1983 Tin Snail
- docchevron
you wont need a bigger turbo.
You can, if you're nuts, get 150BHP from a 17TD.
I did, and it went like hell, for 300 miles...
There's a lot of info about fettling the boost pressure and fuelling on this here forum.
The "search" function be your friend here..
- docchevron
Upped the fuelling, T3 turbo, bigger valves (so big I had to scollop the top of the bores..), ported the head, upped the boost etc etc.. It wsn't actually hard to get the HP, it was much harder to make it reliable.
3 Heads in 3000 miles got a bit silly..
It now runs 115bhp fairly happily..
