split hose (whats it called?)
At the bottom of the strut there are 2 rubber hoses, 1 has split, ive bodged it for the time being my putting a bit of brake pipe between the 2 broken ones, i thiink its a return pipe, any body know the correct name for it, or part number, and where i might buy one. Thanks Chris
leg pipe and GSF used to sell them along with the clip,
here is citroens trade price and part No.
96127591 ADJUST COLLAR 4.13 GBP 4.85 GBP 4.85 GBP
95622818 LEAK BACK HOSE 10.04 GBP 11.80 GBP 11.80 GBP
- Mike E (uk)
Or £5 on E-BAY, okay not O/E but less than 1/2 price delivered to your door !citronut wrote:95622818 LEAK BACK HOSE 10.04 GBP 11.80 GBP 11.80 GBP
Also note that this item does NOT fit an Xantia as the seller maybe suggesting as they only have one leak off pipe (The same as an XM) the BX has two (One to vent and one return pipe) !
- mat_fenwick
- x 19
- MULLEY
Those cheapo's from gsf are rubbish, mine lasted less than 2yrs, i reckon originals will last at least 3 times that if not more.....i'd spend the extra, i'm just going to use up my rubbish one's & then i'll fit the proper one's when i get to them
Ah, I didn't know that...! I'd always wondered, never got round to finding out, and have been using cable ties successfully for the past ten years instead!Mike E (uk) wrote:In case you don't know, the trick to getting the new clip on is to use pincers, the type you use to pull nails out of planks.
Mike
As I say, I've never managed to fit one of the original clips - just use good quality cable ties and have never had a problem.
if/when useing other securing methods just retain the square stainless steel plate from the old clip, this will stop the likes of cable ties squeezing the rubber block to tight at its middle, as this will cause it to kick out at each end and leak
I thought that as i was fitting the new clip, Old square is now saved for next timecitronut wrote:if/when useing other securing methods just retain the square stainless steel plate from the old clip, this will stop the likes of cable ties squeezing the rubber block to tight at its middle, as this will cause it to kick out at each end and leak
Roverman (Tim) Yeah, i hope to be at the show on the sunday,
Im off to Ken Newbolds in the morning to get both rear bearings sorted as there knackered, ive also just changed both bottom ball joints and the n /s drop link arm, 50200 miles on the clock and the old girls starting to cost a few bob!!! i must say the front end feels lovely and tight again, this time tomorrow i hope the rear isnt creaking and cracking,and the wheels dont look like a dropped V-Dub!!
