terrible time starting txd
I cant tell you all about this disaster too much has happened , sometimes she would start , thinking it was the starter at fault i had it tested , its ok , i charged the battery next the ignition switch I tried fitting a push start switch , no good , finally i banged the relay that has been fitted to boost power to the solenoid and then the engine turned over but wouldnt start , it was starting ok with a wire straight to the terminal before i tried fitting the starter switch to by pass the ignition switch . I have bought £50 worth of bits to fit for the mot which looks a long way off at the moment , whilst trying to fit the starter switch i had to experiment stripping the wires till i found the one that went to the starter , maybe i have shorted something , dont know . any advice appreciated , cheers BIll
- electrokid
What is the engine size ?
Is it petrol or Diesel ?
Is the battery the new one you needed or still the old one ?
What's the nominal max current of your charger ?
Do you have a voltmeter / multimeter ?
Where are you based ?
You shouldn't need a boost relay - the solenoid is normally specced for 9v minimum and the battery minimum on starting should be no less than 9.5v.
If it's a modern replacement starter motor it shouldn't be bashed - some modern replacements have ceramic permanent magnets instead of the normal powered field - and these can break if you bash them.
2002 C5 HDi SX estate
- docchevron
it'll be a diesel.
if you take a lead straight from the +ve terminal on the battery to the solonoid does it turn over?
If it goes over but wont start, next thing to check on the starting front would be to see if there is voltage to the stop solonoid on the fuel pump..
terrible times txd
thanks for your replies guys , it is a 1.9 txd , it has been starting with the lead from the battery to the solonoid , i think it may be the stop solonoid , but why would that suddenly fail ? could it have been my tinkering trying to fix up the push starter ? thanks if i cant get it going i will be offering it here for spares .I am in sth devon
- electrokid
Oh yeah - now and then I'm quite brightThe clue is in the title
Why should anything !but why would that suddenly fail
The reason I asked these questions was to find out what kit you have so I could guide you through some electrical tests to try to find the problem. Doc's suggestion is on the button though - or you might have lost the feed to the stop solenoid while fiddling about with the wiring.Is the battery the new one you needed or still the old one ?
And I asked...
to give us a heads-up if there is anyone nearby able to give you a hand.Where are you based ?
re terrible tome starting txd
Hi i have been back to the car , its 9 miles from my house which makes it awkward , there was current at the stop solonoid , when i tried to start it yet again there was just a click so i tried knocking the relay again as that worked last time but not this , i then knocked the box near the battery which i think says pre charger in french the car then turned over and briefly sounded like it was going to fire up . my mechanical abilities i think have been defeated and my frustration levels . This car belonged to a old boss of mine , it failed a mot on brake problems in 08 and has been stood since occasionally getting started and driven on his drive , up until the mot failure it went very well he is a eco warrior and got it to run on bio fuel desiel mix , he gave it to me in return for some work , i am now feeling i wish id had the cash . thanks for your replies Bill
- ken newbold
If the car's been stood some time, chances are it's as simple as a poor connection.
One beauty of the BXD is that the starting system is pretty straight forward.
Carry out the check stated above, also check the solenoid connection of the starter (single yellow) from memory. There is a plug/socket on top of the gearbox that carries the engine wiring harness from the car to the engine, unplug, check and clean these connections.
Down the side of the battery box, you'll see a black box/cover that fits over the positive connections, remove & clean these connections.
I've also known the main battery leads fail, they can get a poor connection inside the lead connector that fits onto the battery.
Remove & clean the main lead at the starter motor.
Sounds like quite a lot to do, but there's only so many things it can be.
thanks very much ken , i am feeling your right , there is probably a loose connection and the stop solenoid might be stuck shut . fir now i am standing back from it as it has rather got the better of me . all the best bill
- docchevron
Hmmm, if it's been run on bio evil fuel then I'd suggest it may well be worth pulling the injector pipes off and have a go at turning it over to see if any fuel is actually being injected.
I have discovered that its the stop solenoid , when i disconnected the wire and reconnected it with the ignition on there was no sound . I cleaned the connectors around the gear box and battery and it turns over . I have also discovered there is rust near the spheres , i poked it and it went straight through therefore this car is now offered for spares , i know the engine is good and all the trimmings are good , there are 3 good tyres 1 is boarder line . I have spent £50 on new spares flexi hoses , pads , wiper, hydraulic pump belt . i Therefore am looking to get £120 for it to cover my outlay . Phone if you like 01364 643117 or 07779636009 cheers Bill I am in sth devon
link for pics
http://screencast.com/t/ODJmZDZlNW
http://screencast.com/t/YzVmMzlj
link for pics
