door mirror
door mirror
Are bx door mirrors the same as for the peugeot 309? cheers.
Re: door mirror
The actual main/mirror/housing is the same, but the door mounting plate is different and therefore will not fit !mds141 wrote: Are bx door mirrors the same as for the Peugeot 309? cheers.
However you can make them fit (But only if there both made by the same manufacturer i.e. Britak) by pulling back the rubber bellow's and remove the torx/allen head set-screw and swap the door mounting back plates over.
Just make sure you take note of where all the washers/spring/spherical pivot ball fits as there quite fiddly to change over and re-assemble !
Alternatively send me a PM with your requirements N/S or O/S (Manual type) or N/S (electric) as I may have a good spare available if required
