Diesel Rev Counter not working
Does anyone know where the pickup for the rev counter is? I have a double connector plug half way down the n/s bulkhead not plugged into anything and another plug on the near side of the engine not going to anything, but the two are obviosly not meant to go together as they are both female.
Thanks,
Adam
Thanks,
Adam
- mat_fenwick
- x 19
- Stinkwheel
Re: Diesel Rev Counter not working
You got a BX again now Adam?adamskibx wrote:Does anyone know where the pickup for the rev counter is? I have a double connector plug half way down the n/s bulkhead not plugged into anything and another plug on the near side of the engine not going to anything, but the two are obviosly not meant to go together as they are both female.
Thanks,
Adam
Ah, ive read the thread now, nice looking car (better than a 5 series)
Doctor Of Gonzo Journalism!!!
93 BX TZD Estate
90 BX 14TE St Tropez
93 BX 19 TXD Estate
92 BX 16TXi
77 Ami 8 Break
79 Acadiane
81 Dyane6
84 2CV6
85 GSA saloon rally car
93 BX TZD Estate
93 BX 19 TXD Estate
92 BX 16TXi
77 Ami 8 Break
79 Acadiane
81 Dyane6
84 2CV6
- docchevron
Every BX I've ever seen has the flywheel TFC sensor regardless of rev counter fitting, but not all had the loom up to the dash.
My RD didn't, easy to add though, you only need an ign. live, an earth and some wires down to the sensor.
If converting petrol to diesel you'll need the rev counter aswell, I'm pretty sure the signal generated by the TDC sensor on a diesel wont fire a petrol rev counter.
- mat_fenwick
- x 19
On mine it's a 3 core grey wire to a brown (I was right!) 3 way connector, I've just checked. Citroen seemed reluctant to use red wires in the loom (but they obviously had a vast surplus of green, blue and yellow) so it may be an aftermarket addition?
I have a photo which I'll try and post up tomorrow.
- mat_fenwick
- x 19
Thanks so much Matt. Unfortunately its plugged in already on mine. There are 3 wires on one side and only two going into the 3 terminal plug coming from the bulkhead, but this looks to be standard. The rev counter dos flinch when I turn the ignition, but thats it. Time for some multimeter and wiring diagram fun I gues
- docchevron
Yes, the thrid wire from the sensor is just a shield wire.
IF the needle kicks when the ignition is turned on then the guage is most likely fine, and has power.
I'll wager it's the tDC sensor itself, either needs pushing in closer to the flywheel, or it's dead.
Still available the stealer for not much.
- docchevron
- mat_fenwick
- x 19
- docchevron
