The Horn
- MULLEY
The Horn
Sorry guys/gals, nothing pervy, bloody horn decided to suddenly stop working yesterday as some txxt cut me up on a roundabout, i was looking forward to letting my prescence be known, but he didnt hear me coming & certainly didn't see me as his axxehole 4x4 nearly shoved me & wifey off the road
Any ideas what it may be? It's nothing as simple as a fuse is it?
- MULLEY
Not going to have much of a chance, on on holiday tomorrow, so will have a look when i get back. Was hoping for a few ideas of what it might be, so that i'm prepared. I fancy a proper double french horn anyway, so i may well get one of those to replace this crappy one which i've never liked....
- docchevron
give the horn a tap, then try again. Still nowt?
Time to get the multimeter out!
Is there +12V on the live wire when the button is pressed?
If not, most likely the feed wire to the stalk, I've had a few fail there recently, which I bypassed and took a feed off the headlamp wire (since it was the fattest live wire in easy reach)..
Earths can be a problem aswell, I've added an earth wire to both of my cars.
- mat_fenwick
- x 19
- electrokid
Wanting to find out which birds were visiting my garden so I could buy appropriate winter food for them I put 'British tits' into Google...I was slightly worried putting in 'rubber horn' into a Google image search...
Didn't get the information I wanted but it was an interesting couple of days
2002 C5 HDi SX estate
- Mike E (uk)
- MULLEY
Nope, used just about everyday to ensure idiots don't come into my lane or encroach on my space. I had a quick look today, i presume i've got to remove the plastic cowling underneat the bumper to get access to the horn, i think i could see it through the large hole behind the headlight area?
- docchevron
yep, it lives under the inner wing, the easiest way is peel the wheel arch liner back fromt he bumper.
Or, fit a P" valver bumper since the tow eye cover also gives just enough space to get to the horn!
- MULLEY
If i do need a replacemnt horn, what about the one below?
http://cgi.ebay.co.uk/Nautilus-Loud-Car ... 5195a79fcb
- Mike E (uk)
IIRC I donated a pair of air horns + a compressor to Phil for the BXagon fund. If he still has those they would do the job.
I have a couple of spare standard BX horns if you need them.
A good clean may be all they need. Check you get volts on the horns 1st.
Mike
Mike
- electrokid
Long time past the same thing happened to me - someone cut me up and the horn not working simply added to my annoyance. After a bit of fiddling under the bonnet I decided it was time to buy a new one.
Now the horn on the Metro was a weedy little 'beep' - the sort of horn that says 'look, I drive a small insignificant little car so please cut me up again if you'd like to - oh and by the way my manhood is incredibly tiny as well'. So I went and bought a triple air horn with separate compressor
This was going to be very loud - so when fitting it I made sure that the horns were pointing through the radiator grille - I didn't want all that noise in the car.
A couple of weeks later driving through Woking - it was a warm sunny day and I had the windows open - the road had 3 lanes between tall buildings either side - then someone cut me up and I hit the horn...
The sound reflected from the buildings and I nearly jumped out of my skin - scared the living $%^ out of me
