Damp seatbelt
- electrokid
Damp seatbelt
Jumped into the BX yesterday morning and the seatbelt felt a little damp. Pulling more of it off the reel showed that the rest of it was very damp and knowing that where dampness lurks the red worm is sure to follow I think this needs fixing.
But where is this water getting in - how is it getting to the seatbelt reel - and should it be draining anywhere ?
2002 C5 HDi SX estate
- electrokid
- docchevron
- electrokid
The belt should be protected from water in the sills by a plastic insert. The B-post itself has to drain holes at the bottom edge where it meets the sill – it's possible that if these are blocked the B-post could start to fill up, but I would have thought you'd notice the carpets getting damp before the seat-belts (although I suppose you don't put the carpets over your shoulder every time you get in the car...).electrokid wrote:Great - I'll look into those - thanks.
Should it drain out the bottom of the sills - I've recently de-rusted / resprayed and squirted waxoyl all over the place - have I bunged up something that should be clear ?
If you open the doors and look the B-post, the drains are pretty obvious - give them a poking at with a bit of wire. However, if they're badly blocked they're easy enough to clear properly from the inside oce you remove the seatbelt reel.
The fundamental question would still be why so much water was getting down there in the first place. I've just had a look at the bare, doorless shell of my spares car - it's been tipping it down here for days and neither of the B-post sections is noticeably wet...
- electrokid
- docchevron
I tend to agree with that diagnosis, my door is slightly out of alignment and thats where I noticed or should say could hear the water coming in.Way2go wrote:Probably the door seal being damaged or not being compressed properly when the door closes.
With all this rain, when driving it probably "wells" up at the bottom of the door entering the car by the "B" pillar just above the inertia reel.
The month of September the TRS only came out the garage once and even though I thought the sunroof was in good order I still manged to get a shower after parking it at work one day. Then again given the 600mm (2 foot) of rain that fell around here (a record for september) that would be no surprise. The swamps around here after two solid weeks of rain testify to that.
