Trying to determine which ignition leads I need for my 1989 BX 1.9GTI (8v), Haynes lists as Champion LS-10, Halfrauds claim Bosch 803 (but do not stock them) and on flea bay I have come across a set of Champion LS-55 that will apparently do the job. Can anybody advise if the LS-55 will be OK or even tell me what the differences are apart from the obvious of different connector types??
Thanks in advance
Ignition leads - Which ones
1989 BX19-GTi Auto in "Gris Axonite" - Coming together sloooooowly.
1988 VW Golf 1.6 CL Auto
1995 Volvo 850 T5 Auto Estate
the OE leads would be Bougicord i think its spelled somethink like that, and the OE leads will have the corectly fitting rubber boots at both ends,
try GSF as they used to stock them
