Hi
I recently had a new head gasket fitted by a mechanically minded friend, My problem is that oil residue is still in the coolant when I take the radiator cap off. My friend said to give the engine a flush out. Another friend said the mechanic he uses says the best thing to use, the cheapest is to use a dishwasher tablet or two? has anyone else any suggestions or is this ok? and what is the best procedure?
thank you
Mark
What is the best way to do an engine coolant flush
- docchevron
Never used dishwasher tablets!
I usually drain the system down, add some proper flushing agent (Forte is good) fill with water, run up to temp, empty it out and repeat until it's all nie and clean looking, then refill with coolant.
- docchevron
I usually pull the rad out and back flush it, if I'm feeling very decident then I've been known to remove the thermostat and flush the engine through, but most often the crap collects in the rad anyway.
- electrokid
- docchevron
nevr have in a BX no, in some other stuff yes, but I've never had cause to yet in a BX mate.
I fitted a new one tot he red car about 8 years ago after the old one became incontinent, but even then it got good and hot all over!
