[quote="anorthfield"]Mulley - I'm in Epsom, so thanks very much but it's not practical.
You should be able to buy the stuff from any decent motor factors, i forget what its actually called, but someone in the shop will probably know what it is when you mention tank fungus, i think it was about £7-8 for a bottle which does quite a few tankfuls, which i guess is handy to do a few times to ensure that the fungus is all killed off.
Intermittent diesel stalling and no power
- MULLEY
A restriction in the fuel line (sludge or partial blockage) will normally manefest itself as cutting out when a higher demand of fuel is required i.e.
When rapid acceleration or hill climbing. The injection pump demands more fuel than is supplied causing a vaccum in the supply line, It will often restart after it has cut out because the vacuum has had time to replace the fuel shortage.???
- citsncycles
My RD had suffered like this due to what turned out to be a perforated pre heater pipe. Under normal conditions it seemed fine, but under load it would suck air in, stalling the engine. Generally by the time we'd coasted to a halt the engine had already pulled most of the air through and it started again.
