Sump plug question
Sump plug question
Hello knowledgeable folk.
Does anyone know the dimensions of the square hole in the sump plug and if there is a cheat to undo it.... ie does a 1/4 or 3/8 square drive fit etc etc etc.
I would go and measure it but I don't fancy laying in the snow.
Thanks.... Rich.
Thanks.... Rich.
'86 2CV Dolly
'81 2CV 007 Drummer
'82 HY Shorty
'77 Smurf blue Ami8
'81 2CV 007 Drummer
'82 HY Shorty
'77 Smurf blue Ami8
No sorry mate it's not that simples, it's inbetween 1/4 and 3/8 so I would guess 5/16"
or yes 8mm
or yes 8mm
- ken newbold
That's what I wanted.... Geniusken newbold wrote:Here's todays useless piece of information.
The square shaft that goes through most house door handles is a really good fit. The bad news is they're pretty soft and not much use as they twist up if your plug is tight.
Right... Time to cannibalise my lads bedroom door.
'86 2CV Dolly
'81 2CV 007 Drummer
'82 HY Shorty
'77 Smurf blue Ami8
'81 2CV 007 Drummer
'82 HY Shorty
'77 Smurf blue Ami8
It depends how often you're going to do this job, I would advise buying the actual 'bit' or fitting whatever it's called to go on the ratchet drive. I bought one made by Hazet a few years ago for €15. Seemed a bit expensive but it's earned its place. I'm sure there's an equivalent piece available in Uk - what do other people use?
Every sump nut I've seen on a BX has been bodged out of shape by various different 'solutions!'
P.S yes, it's 8mm and I think Hazet ( German tool maker) make them for Citroen.
- MULLEY
Can't remember the brand, but most local motor factors have a range of sump plug keys, they didn't have the one i wanted as a single, so for about £8 i bought a pkt of about 5 instead which did have the one i wanted. I've kept the others, just incase i might need one if i have another car which has a different size.
- Stinkwheel
As mentioned above Rich, most motor factors (even halfrauds) will stock a draper or sealey tool for these as they were fitted to a lot of pugs and cits for years. Should be about 7 quid, i think mine was about fiver a few years back (actually 23 years back, it may be more money now )
I would offer to lend you that, but ive no idea where it is at all,
If i remember rightly a ground down 3/8 adaptor was used last time i did it.
Doctor Of Gonzo Journalism!!!
93 BX TZD Estate
90 BX 14TE St Tropez
93 BX 19 TXD Estate
92 BX 16TXi
77 Ami 8 Break
79 Acadiane
81 Dyane6
84 2CV6
85 GSA saloon rally car
93 BX TZD Estate
93 BX 19 TXD Estate
92 BX 16TXi
77 Ami 8 Break
79 Acadiane
81 Dyane6
84 2CV6
- Stinkwheel
ignore my maths, thats more like 13 years ago with a miss typing, im not that old yet)
93 BX TZD Estate
93 BX 19 TXD Estate
92 BX 16TXi
77 Ami 8 Break
79 Acadiane
81 Dyane6
84 2CV6
93 BX TZD Estate
93 BX 19 TXD Estate
92 BX 16TXi
77 Ami 8 Break
79 Acadiane
81 Dyane6
84 2CV6
Went to drain the oil out of the scrapper yesterday prior to lifting the shell off the lump, nothing came out. I assumed I must have already drained it at some point. Not so - sump was half full of water, which was frozen, blocking the drain hole!
Sump plugs are still available from citroen main stealers.
