can anybody help my front near side door has dropped, when I bought my bx it had had a crude repair done to the upright door pillar where the top hinge attaches it had rotted through and been welded now this weld has begun to break and the door has dropped. Is there a replacement panel or any other ideas of a repair for this problem. I'll take a picture when it is lighter outside and post it up so you can see what I mean.
Thanks
Dropped passenger door
I dont think there are replacement panels for the pillars. I suppose you could cut a repair section from a scrapper if you can find one or what ive had to do is take the front wing off and rebuild the top of the existing pillar as neatly as poss.Its a very common fault.
Richard.
Richard.
1985 MK1 BX Digit
1986 MK1 BX Leader
1988 19RD
1983 Tin Snail
1986 MK1 BX Leader
1988 19RD
1983 Tin Snail
- docchevron
I would like to make it quite clear from the outset that I am not available for this position and would ask that you refraim from putting my name on a list of possible contenders. Thanking you.Linegeist wrote: Either that or have babies with someone who already HAS one!
