Bearing X-Ref
- JayW
- x 13
Bearing X-Ref
Does anyone have any cross reference part numbers for the rear arm bearing (cit 75472408). SKF or Brammer etc???
I know i've seen them somewhere but can't find it.
Cheers.
Cheers.
- mat_fenwick
- x 19
- JayW
- x 13
That's right Mat, i know someone HAD posted another part number for the races themselves a long time ago but i can't find it now.mat_fenwick wrote:I think what Jay is after is the part number for the actual bearings themselves rather than the kit - I have (had?) a Timken box with a part number on it; however when I tried I could not match this with other bearing manufacturers on the 'net.
Worse comes to worst i'll go to Brammer meself for it...
Last time I installed them, the box said "BCAB 326332 B":
http://www.rmattila.com/images/remontit ... .jpeg.html
-Riku
-Riku
BX Van 1.9D -90 Gone.
BX Van 16S -90 For sale.
Are you sure of that?Brian wrote: O/D 44mm
EDIT: Found the following: http://www.albeco.com.pl/katalogi/zamienniki.pdf
They appear to match with the old parts manual:Brian wrote:How do the other dims stack up?
Thus I suspect that the SKF standard taper roller bearing SKF 442327N won't fit and you have to use the above mentioned BCAB 326332 B (=A&S F 15028 = IRB IR 2053 = OTROS TIMKEN - JL 22349 / 10 F according to the cataloque linked above) instead.
EDIT: and that chinese page seems to give 0.1 mm larger value in the axial dimension (14.5 mm instead of 14.4 mm).
- JayW
- x 13
22x41x14.4
Available here if anyone wants any:
http://simplybearings.co.uk/shop/p40062 ... _info.html
Half the price if Cit.
They are the same for BX, Xant & C5 amongst others.
It was me (JL22349F Timken) in THIS threadJayW wrote: ............... I know someone HAD posted another part number for the races themselves a long time ago but i can't find it now.
