Okay - I finally decided to do the job yesterday, after a year of procrastination (and trying to balance the said visor so I could see to drive).
Spent an hour assembling the tools (mainly a torque(?) drive) - took the broken one off - this mechanics lark is easy-peasey. Fail, it's the wrong type of visor (too short). Pulled the bracket out of the old one and it seems to work just by friction - so another half an hour borrowing a pair of pliers (mine have disappeared) and a good, grunting squeeze and hey-presto it stays in place now!
Took off the exhaust shield too, which was rattling like a demented pneumatic drill.
I think I will get the garage to fix the rattle from the front suspension
Changing a sun visor (fail!)
Think i have a rattling exhaust heat shield as well, sounds like the front one. Was it easy to remove/repair?
Re: Changing a sun visor (fail!)
If it's the one that protects your Hardy disc, I hope you replaced it as you don't want to be cooking that rubber!scarecrow wrote: Took off the exhaust shield too, which was rattling like a demented pneumatic drill.
What's a hardy disc!?! I asked the Citroen mechanic who looks after the car and was told it'd be okay to take it off... It's not really a shield - more of a preheater for the air intake - but as I have Konan the Barbarian air filter thing on top of the Carb now it was pretty much redundant.
The thing rattled because one of the bolt holes was corroded - a big washer would have fixed it. It's located over the front inlet manifold and there were three small bolts holding it on that looked corroded but came out easy enough.
- mat_fenwick
- x 19
- mat_fenwick
- x 19
