Gave the GT a mini tune up today as well as an "italian tune-up" fun fun!!
Got me thinking about the possibility of putting a free flow air cleaner to feed the carb...has this been done b4? ...is there enough space to mount a foam air filter on top of the carb or does it need to still be ducted from elsewhere..
Plus is the original pseudo ram air collection going to be better than messing with having a free flow air filter...just that the carb sounds really good when its un-muffled and it may just make the GT even peppier..
weber free flow air cleaner
Current
85 BX GT Mk1..
86 BX TRS Mk1
87 BX TRi
Gone
85 BX TRS mk1 auto... SOLD
90 BX TRi..parts....cubed
85 BX GT Mk1..
86 BX TRS Mk1
87 BX TRi
Gone
This is what I have on my GT. Cold air is ducted up from front spoiler below the head lamp and onto the cone filter which is separated from the rest of the engine bay by a piece of sheet metal. The pipe is made of PVC which I later spray painted black.
1989 Citroën BX 16v
1993 Citroën BX 16v project
- citsncycles
I can't say with BX's in particular, but I would consider carefully before replacing ram air with a free flow filter. The free flow filter may work better at low speeds, but the ram system would be better at higher speeds - it will all be down to how well your ram system works.
Personally I would try to incorporate a free flow filter element into a ram air collection system, that way you'll get the best of both worlds.
Also, be prepared for it to not make any difference at all - another part of the system may also be operating at peak efficiency. I hit this problem with the Lomax I had. I started with twin exhausts, effectively doubling the cross sectional area for the exhaust. I then fitted a K&N filter, and as a result I had to screw the mixture screw almost all the way out to get it to run properly, and really should have fitted a bigger main jet to cope with the increased air flow. I got better performance but at full speed the fuel consumption was quite staggering for a 602cc engine, emptying a 14lt tank in around 80 miles!
Yes I agree, am working on such a system at the moment...but first I now need to work out a very intermittent "fuel" issue..citsncycles wrote:
ie engine will rev but not have enough power to move the car at all... eventually the problem "clears itselt",, but very disconcerting just when you think you've nailed the tuning/setup/reliability
Current
85 BX GT Mk1..
86 BX TRS Mk1
87 BX TRi
Gone
85 BX GT Mk1..
86 BX TRS Mk1
87 BX TRi
Gone
- citsncycles
Apologies if this ground has already been covered, but could this be a clogged fuel filter or a collapsing fuel line?
