Clutch Cable Fitment
- Tim Leech
- x 150
I have a new old stock genuine clutch cable, part number 95162700, im hoping it will fit my 19TZD?
Anyone?
Cheers.
Anyone?
Cheers.
- ken newbold
Can anyone give an idiot's guide to changing the clutch cable on a TZD without actually removing the engine or at least large parts of it? I can't for the life of me see how to do it as there's no way to get at the bulkhead on the engine bay side to get at the fittings.
- ken newbold
That's the easy bit though - I got that far last time. But the cable holder is attached to the bulkhead from the engine side, and I couldn't get the cable through the holder/grommet bit without breaking it. So clearly I'm missing something, but what? (Apart from a load of brain cells, obviously... )ken newbold wrote:Remove the pedal box from inside the car, simples
- themildbunch
I think it's usual to remove the bottom engine mount by the driveshaft so you can get the engine forward as much as possible to get access from below... Probably removing some of the turbo trunking would help too..
I'm not going there though unless it actually snaps!
I have a new cable as a spare too but this adds to the difficulty due to the revised arrangement on the pedal box side with the white nylon snap ring which is apparently a lovely fiddly citroen type thing to get you swearing...
1988 BX 19 Gti 16v
1991 BX 17 TZD Estate
- ken newbold
I'll have another look next time it's up on the ramp, but I'm sure I remember deciding the cable would only go through the grommet by breaking something. We'll see.
- Tim Leech
- x 150
well as a clutch cable is peanuts compared to having a new clucth fitted (not in my realm of mechanics) and has previous cured a very sticky stiff clutch on the valver iim gonna try that first!Way2go wrote:Surely that's due to the clutch pressure plate & mechanism, not the cable?
