Hi
I've taken off the rear subframe for a little rust treatment on my BX 4x4.
As its all off (and some of the pipes cracked in the process) I've decided to replace all the lines going to the rear of the car (I'll do the ones to the front when it facing the other way in the garage)
My problem is that the nuts that hold the lines in place are very rusty and seem to have shrunk over the last 20 years, by shrunk I mean they don't seem to be a very snug fit on any metric size spanner and being french I'm assuming they should be metric.
what do people use to undo these nuts without destroying them? I don't want to leave half of them in the brakes etc...
thanks
hydraluic line replacement
1991 BX 4X4 GTI back on the road
- ken newbold
- ken newbold
Yes, "shear" is what I meant
I have in the past managed to drill out the old unions left in, tricky but can be done, especially when you don't have any spare parts lying around.
I have 2 rear cylinders in the garage at the moment, one of which has had such treatment. These will be offered for sale shortly once the cars have gone.
- ken newbold
Yes, as soon as my new wheels arrive. Mind you, getting info out of ebay sellers is like pulling teeth at the moment, so it might not happen just yet.
But now virtually all the spares have gone, I think it's time for the cars to go too. One of them has got a buyer already, the other one will be offered on here first.
- ken newbold
first thing i try if the an 8mm flair nut spanner fails, i cut the pipe off leaveing a short stump then use a hex socket and ratchet, as this will usualy grip a slightly rusted away pipe nut,
if this fails a quality set of VISE grips are the next opption,
