I think I'd be inclined to take that as an indication that they didn't need changing quite so often!docchevron wrote: I always change the tensioner / idler / pump every other belt change (I change belts every 20K miles) and the pumps have always looked and felt as good as the day they went in..
Replacing Waterpump During Cambelt Change
So this is proving not to be the DIY job to be done with a set of axle stands and car ramps
My local Garage has found the easiest part of the job was replacing the waterpump the tensioners are giving them grief and of course thats put the removal of the gearbox to get the clutch dine behind schedule. It does not help when the blardy fire siren goes off which results in no one left in the garage to work on any vehicles.
Joys of a small village if you have a vehicle in the workshop and the Fire Siren sound during the day then dont expect you vehicle to be ready at the end of the day
1990 BX19 TZS Auto 06/11/1989
Trouble is the shell was never designed for these engines, so there's bugger all access at the cambelt end. In the past I've ended up jacking the engine up in the bay to get at one bolt, then letting it all the way down to get at another, and so on. It's not a job I look forward to!
- docchevron
this is true, but for peace of mind and the little cost I do it anyway, ok I dont have to pay garages and such, if I did that would have a bearing on frequency!KevR wrote:I think I'd be inclined to take that as an indication that they didn't need changing quite so often!docchevron wrote: I always change the tensioner / idler / pump every other belt change (I change belts every 20K miles) and the pumps have always looked and felt as good as the day they went in..
