rear end knock
rear end knock
Help im going demented my bx saloon has a knock on the o/s/r going over bumpy ground ive been to my tame mot tester and we checked everything all we could find was a tiny bit of play in the rear arm and a rumbly bearing. I replaced the rear arm and bearing today and the knock is exactly the same (and i broke a brake pipe just to put icing on the cake) THe only thing i can find loose is a bit of play in the leg on its miountings but as both sides of the car are the same i cant see this being a problem can anyone help pplleeaasseee
- JayW
- x 13
Sorry, i missed the bit about the movement (reading on my phone)garfield wrote:are the legs supposed to move then
NO, there shouldn't be any movement in the rear arm (other than up/down).
If there's side/side movement then your rear arm bearings are shot (as is the one you replaced it with by the sounds of it). Theses will definitely cause knocking & creaking.
Are you talking about the rear suspension strut / leg as you've replaced the rear arm bearings? the strut does move about when there is no pressure on it.
