Squealing HP pump.
Squealing HP pump.
Hi all.
Over the last few weeks the HP pump has started to squeal on the BX. I have checked the belt tension and that seems OK. The steering is also heavier and not as smooth as it was.
Is it new pump time???
'86 2CV Dolly
'81 2CV 007 Drummer
'82 HY Shorty
'77 Smurf blue Ami8
'81 2CV 007 Drummer
'82 HY Shorty
'77 Smurf blue Ami8
If it's squealing it still only points towards belt tension or worn belt. The pump belt does need to be very tight. A worn pump doesn't normally squeal unless it is physically locking up?
- Stinkwheel
Rich,
Just a thought and im sure you know, but the HP pump belt have to be set much tighter than yer average alternator belt.
Doctor Of Gonzo Journalism!!!
93 BX TZD Estate
90 BX 14TE St Tropez
93 BX 19 TXD Estate
92 BX 16TXi
77 Ami 8 Break
79 Acadiane
81 Dyane6
84 2CV6
85 GSA saloon rally car
93 BX TZD Estate
93 BX 19 TXD Estate
92 BX 16TXi
77 Ami 8 Break
79 Acadiane
81 Dyane6
84 2CV6
- MULLEY
Tight enough that when you push on the belt, it should hardly flex/move
- Stinkwheel
Exactly what the other Matt said (aka Mulley)
Almost no deflection, not like a normal belt.
93 BX TZD Estate
93 BX 19 TXD Estate
92 BX 16TXi
77 Ami 8 Break
79 Acadiane
81 Dyane6
84 2CV6
93 BX TZD Estate
93 BX 19 TXD Estate
92 BX 16TXi
77 Ami 8 Break
79 Acadiane
81 Dyane6
84 2CV6
- mat_fenwick
- x 19
on the belt not your bumBX Meteor wrote:talcum powder sometimes helps that
try turnning the pump pulley by hand when the system is up to presure,
